Possible bug: In process stock now showing in really low quality
BWENGUK
Message 1 of 21
BWENGUK
See below screen shot. Normally the stock you see as you add new strategies is decent quality, ie you can see things like counter sinks clearly. As of 2 hours ago this is now not the case. Has something been updated or is there a setting where I can change this? My accuracy within simulation is already set to the top end of the slider, but this isn't from within the simulation tab.
Replies (20)
Message 2 of 21
BWENGUK
To add some more confusion to this. I just went back to a project I did yesterday and it still looks completely normal.
Also, the project with the previous issue now has another issue where zooming in makes the 'stock' go completely dark.
Message 3 of 21
mattdlr89
I'd guess this is some kind of graphics card issue. Is there a driver update available? Have you tried the usual restart of Fusion and PC?
As far as I know there isn't any way to set the accuracy/tolerance of the IPS stock model.
Message 4 of 21
BWENGUK
Tried restarting everything, and everything is up to date etc. It's just most bizarre given the previous jobs look normal when I go back to them and look at it.
Message 5 of 21
accounts946HE
Hello... Did you ever correct this. I have recently been experiencing the same issue and now cant not clearly see the stock cut. Just jagged edges etc. Its very frustrating and happening across all my devices. Help would be much appreciated.
Message 6 of 21
seth.madore
Hmm, that does look rather poor. Could you share your Fusion file?
File > Export > Save to local folder, return to thread and attach the .f3d file in your reply
Seth Madore
Message 7 of 21
BWENGUK
@accounts946HE I never solved this issue. It only occurred for this one file. Every other file is fine, and has been fine since. It's bizarre!
I've just gone back and loaded that original file and it is still doing the same thing, even loading it back in a year later.
@seth.madore I've saved a copy of this file for you to look at in case you can see anything wrong? It's no longer an issue for me as it was just this one document, but might be good to find the original cause in case it pops up again!
Message 8 of 21
haveoneforme
I am having the same problem with the in process stock being of such a low quality that any following Rest Mill operations are unusable.
Is there a way to up the polygon count for In process stock for larger jobs ?
Message 9 of 21
seth.madore
Would you be able to share your Fusion file here?
File > Export > Save to local folder, return to thread and attach the .f3d/.f3z file in your reply.
Seth Madore
Message 10 of 21
haveoneforme
Here's a simpified version.
The job is quite long at 1500mm.
Message 11 of 21
seth.madore
Unless I'm seriously mistaken (and have been for years), the In-Process Stock doesn't have an impact on the quality of the Rest Machining process. Rest Machining is taken from an STL (mesh) that is generated in the background, the IPS is a rough representation of said STL file.
Seth Madore
Message 12 of 21
haveoneforme
Unfortunately, that does not appear to be the case with the results I am having, I've updated the file with two identical rest machining toolpaths, the only difference is one references the previous toolpath as remaining stock (In Process) and the other references an exported stock mesh model taken from the first two operations.
As you can see the In Process referenced toolpath is not correct.
Message 13 of 21
brekmiller
You are right Seth, rest machining does not use the IPS meshes.  You can prove this to yourself by turning off the automatic generation if in-process stock and deleting all of the meshes.  Now you will see that all toolpaths show that there is no in-process stock.  Regenerate the rest-machining toolpath, which will work, and there will still be no in-process stock on any toolpath.
The rest-machining meshes are calculated by the same code in a very similar way and they are cached in the same directory as the IPS meshes though.  The tolerances used are similar but not quite the same.
You don't have direct control over the tolerance but you can influence it by changing the value of the "Surface Triangulation Tolerance" on the rest toolpath.  I think you need to use Compare and Edit to do this.  Reducing this tolerance will make the rest stock "better".
However, it might not help much in this case.  Your part, and thus your stock, is very long and skinny.  We're aware that there is an issue with IPS and rest stock with stock like this.  The resolution that Fusion chooses is based on the longest dimension of the stock.  That's a poor choice when there is a large difference between the largest dimension and the smallest dimension.  Reducing the "Surface Triangulation Tolerance" might not be able to completely compensate for this.
Brek Miller
Software Engineer
Message 14 of 21
haveoneforme
Thank you Brek for explaining why it is not  In Process Stock that is causing the poor quality Rest machining toolpaths in Fusion.
I have updated the model so it doesn't look "long and skinny" and improved the "Surface Triangulation Tolerance" ten fold. Both had no visible effect on the quality of the toolpath.
Do I have to start a new thread on Fusion not being able use rest machining on larger components ?
Again thank you to yourself and Seth for your help.
Message 15 of 21
BWENGUK
This fundamentally appears to be the answer to my original thread! I've run into this problem many times since, as we're often doing pockets in handrails that involve milling it out then treadmilling. Because I model the whole rail, this leads to terrible IPS simulations. But now I know why!
Message 16 of 21
haveoneforme
Thanks for you and brekmiller help explaining why I can't expect Fusion to produce good quality rest machining toolpaths and In Process stock simulation with Fusion on larger jobs.
Brek does explain that they are aware that Fusion has a problem with larger job with small details.
So this explains why it's happening , can I ask if there are any plans to this issue to be addressed ?
We have a few large machines and have just bought extra licenses to use with them , only to run into this problem straight away.
Message 17 of 21
seth.madore
Have you tried adjusting the Triangulation Tolerance in Compare and Edit?
Seth Madore
Message 18 of 21
haveoneforme
Yes I have increased the tolerance ten fold and unfortunately it has had no effect on the toolpath quality.
The problem does not just effect the toolpath quality but also the simulation quality.
I've attached the file
Message 19 of 21
eerier_bleach0f
Ya I get that every now and then. Very annoying. Usually just need to regenerate all my toolpaths in every setup and cross my fingers that Fusion doesn't crash beforehand or have a toolpath hang that 30 minutes later still hasn't generated but if I simply copy/paste the toolpath the pasted one will generate in 5-10 seconds lol. And then of course I'll notice that IPS won't generate past the first toolpath so I'll just need to generate everything all over again, turn IPS off/on, restart the program, and hope and pray. Very flaky program.
Autodesk's most dedicated bug reporter: https://forums.autodesk.com/t5/user/viewprofilepage/user-id/15188348
Message 20 of 21
seth.madore
Great, thanks for sharing your file and raising this issue. We're having discussions on how we can improve the results, but it's early stages yet.
I'll admit, I wasn't aware of the link between Rest Machining and "size of part".....
Seth Madore
