Points after whole numbers in G-code
williammaisch
Observer Observer
williammaisch
Observer
Observer
i have a problem with my G-Code.
I am using the WinPC-NC Post Processor to create the G-code. After loading the G-Code into WinPC-NC it just shows a distorted mess. I found out that the cause of this problem is that there is a dot after every whole number. After deleting all the dots manually it works alright.
(1001)
(T1 D=10. CR=0. TAPER=45deg - ZMIN=0. - Fasenfraser)
N10 G90
N11 G71
(Gravieren1)
(CHANGE TOOL)
N12 T1 M06 (FASENFRASER D=10.)
N13 S5000 M03
N14 G54
N15 M08
N16 G00 X-136.65 Y-107.12
N17 G00 Z16.              <---------------like here
N18 G00 Z5.
N19 G01 Z0. F1000
Does anyone have an idea why the dot causes problems or how to get rid of it?
Thanks in advance
William
Hi!
this is a setting in your post processor. Do you know how to edit your post?
if so. search for this line: var xyzFormat = createFormat({decimals:(unit == MM ? 3 : 4), forceDecimal:true});
when found you need to set 'force decimal' on false (just change the word true to false).
Always be careful whenever you changed the post.
Coert
