Pocket NC - Machine type
awr4sc
awr4sc
Just working through the manufacturing setup and I have an option to select a type of (milling) machine (see png).
Just wondering which one should be selected for the Pocket NC V2
johnswetz1982
You dont need that to post out any code. That is just a sort of bonus work in progress type of deal for right now. though you can fill out the info if you really want. I suggest storing it somewhere other than the default location so that it does not get overwritten in the next update.
awr4sc
Thanks for the response, unfortunately it seems that if I do not pick a machine I receive this error:
"Enabled feature flags: additive context-aware-menus drill-wizard machine-configuration probe-geometry-strategy strategy-inspect-surface strategy-steep-shallow
Error: Setup1: Model has 1 missing selections."
I'll work through the cam options again, but picking a random machine allowed the tool paths to generate; not picking results in the above error?
johnswetz1982
That is because you probably tried setting the CAM setup with it enabled previously. As @jeff.pek responded to you previously your error message is from a missing body in your CAM setup. You have to either clear your selections or reselect the body.
"Error: Setup1: Model has 1 missing selections."
awr4sc
Thanks, just learning all of this. I quickly glanced at Jeff's response, not connecting the issues. I see the error now.
Thanks again,
