Pipe Coupling
Pipe Coupling
varun.hariprasad
Pipe Coupling
varun.hariprasad
I made a 3d printable pipe coupling to use with a pipe I currently have? Would the pipe go into the pipe coupling and are the threads compatible? I have attached a file containing both the pipe and the coupling.
Thank You Very Much
daniel_lyall
Posting the fusion would be better, Have a look at the info here you can use section analysis to help determine if it will fit before you send it out as a .stl https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-333900B8-2C26-4341-B10C-B1B63EDE7DEC
It also depends on what material the coupling is made from it is not a simple yes no.
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
