Parallel Toolpath creating gully channels with minor Z axis moves.
Problem:
When processing with parallel toolpath it creates gully channels on the surface (depth is likely 0.3/0.4mm).
It makes it especially at the lines where it connected to some circular shapes on the flat surface.
Prior to my previous toolpaths on parallel, only difference that I felt is feed optimization is enabled before. However on the previous works I have not seen toolpaths created by feed optimization as well. So this is kind of odd to me.
And Interestingly when I ran simulation, I can see the similiar output on simulation rendering. I am confused at this point if it is a setup problem, gcode problem, processor problem or machine problem at all (Machine works fine at that areas without this toolpath.)
P.s: It doesnt matter if I change the pass direction to 0 or 90 degrees. Same gully channels at same starting point happens again aligned with that pass direction. Therefore I highly suspect on something wrong with toolpath creation.
Tool Used: 3mm ball end-mill carbide
Material: Aluminium 7075
More photos at the attachment to give an idea.
