overhang machining with robot
Hello everybody,
I would like to machine a 30° overhanging piece. I can't find a solution on fusion to bring my tool on the underpart of my surface. I'll achive the work with a 6axis robot
Is some one know what type of fusion tool use to get a sucessfull toolpath ?
Thank you
Paul
seth.madore
Tool Orientation and Scallop would be my first choice
Seth Madore
u cant do 3d machining undercut in fusion, u can do it with a 3+1 or 3+2 setup to tilt the tool and then apply a 3d operation. even on simultaneous 5 axis or within any 3d operation with multi axis tilt enabled the max u can get its the software to tilt the tool to dont collide shaft or holder into the part and still not machining undercut surfaces.
u can do this really easy on fusion just indexing
Thanks a lot Seth,
It works perfectly !
Thank you so much.
Paul
Thank you,
I realised the 5axes is not completly magic !
thank you
Paul
