Output partial bore/boss probing angles as positive
Eric_Evans_a_GiroDisc_com
Trying to add 3 point cycles to my Brother Speedio w/Blum probing post.
The function is the same as for Renishaw except the angles need to be output a 0 < 360, vs +/-180, and they are coded as HUV, vs ABC.
How can I get those angles to output as positive numbers?
The post utility doesn't include any samples of partial/angle driven cycles and searching through the post for keywords like partial, circle or angle has just taken me in (full, not partial!) circles.
seth.madore
Give this a try:
"H" + xyzFormat.format(xyzFormat.getResultingValue(cycle.partialCircleAngleA) < 0 ? cycle.partialCircleAngleA + Math.PI * 2 : cycle.partialCircleAngleA)
Seth Madore
Thanks for the assist Seth!
From Left to Right:
Stock post, your attempt, my adaptation of yours
The partialanglecircle output is -A degrees, so I just needed to add that back to a full 360.   Thankfully you handled the logic and syntax I just needed to fill in the blanks!
"xyzFormat.format(xyzFormat.getResultingValue(cycle.partialCircleAngleA) < 0 ? cycle.partialCircleAngleA + 360 : cycle.partialCircleAngleA),"
