OUPLAN With Automatic Tools Post Processor - Github Sharing
x3msnake
Message 1 of 15
x3msnake
Greetings
I Have made for my own use a PP for the Portuguese Brand  of CNC machines Ouplan.
It is published and shared it in my github
https://github.com/X3msnake/Ouplan-CNC-Fusion-360-Post-Processor
steelpro
Best Regards
V.
Replies (14)
Message 2 of 15
al.whatmough
Nice work.  Do you want us to add this to the library of Stock post?
AL Whatmough
Director Product Management - Manufacturing
Note, I love to engage on the forums. However, I spend a lot of time in meetings trying to help clear the path for our amazing team of Developers working on Manufacturing at Autodesk. So, if I don't respond immediately, it's not that I don't care.
Message 3 of 15
x3msnake
Sure, why not 🙂
Com os melhores cumprimentos,
Vinicius Silva
Message 4 of 15
Very good 😉 Will it work with an Ouplan 3020?
Message 5 of 15
x3msnake
yes, probably out of the box
Vinicius Silva
Message 6 of 15
Nice.. I'll give it a try tomorrow.
Btw.. I think we've met in Fabrica Moderna last month 😉
Message 7 of 15
x3msnake
Yeah i though it was you 🙂
Hope it is usefull
Drop me a msg here with the results of your testing
Message 8 of 15
Hey Vinicius..
Everything is working 😉 thanks
Just have one issue but i think it's software related. When creating the NC file, it gives an error about the WCS and uses G53 instead of G54. I've been manually correcting this but is there a way to fix this?
Thanks again
Dave
Message 9 of 15
x3msnake
That's not an error
It is a feature. It warns the user what wcs is selected, since you can use any of the machine's available Coordinates (G54-G59) for machining by setting it up in your inocam's jog panel .
In the wcs setup you must use wcs offset 1 or higher.
User-added image
Anyways the script was designed to default to G54 if the user forgot to set the right offset so there is some issue there.
Can you share with me a cam setup that you have that is giving you that issue?
Message 10 of 15
x3msnake
I've updated the post on Git to fix the WCS validation issue
Now when a user forgets to change the WCS in setup>postprocessor>wcsoffset it defaults posting to G54 and alerts the user of this
Message 11 of 15
Sorry, it was my day off, i couldn't check that.
Tomorrow i'll send you the settings and a copy of the start and end of the gcode where i had to change. I'll give it a try with the new update 😉
Thanks again
Message 12 of 15
So part of my problem i'm pretty sure is due to the fact that the network and user permissions don't allow Fusion to run properly. It gives an error saying "Fusion is unable to install Brackets due to unkown error" when i try to access the post-processor configuration menu.
The gcode now starts with G54 by default but remains G53 in the end.
:1248
(Made in : Autodesk CAM Post Processor)
(G Code optimized for Ouplan 2515 with InoControl controller)
(Program Name : teste2)
(1 Operation :)
(1 : Morphed Spiral2)
(  Work Coordinate System : G53)
(  Tool 8 :Flat End Mill 2 Flutes, Diam = 4mm, Len = 13mm)
(  Spindle : RPM = 15000)
(  Machining time : 1 min 27 sec)
G40 G17 G80 G49 G21
(Operation 1 of 1 : Morphed Spiral2)
G90 G54
G0 X0 Y0
T8 M6 M9 M3 S15000
G0 X0.308 Y0.308 Z15
G0 Z-1.064
G1 X0.308 Y0.308 Z-2.641 F1000
X0.216 Y0.216 Z-2.936
X34.459 Y30.328
G2 X34.788 Y29.595 I-0.792 J-0.796
G1 X34.796 Y27.784
X35 Y-30
X35.001 Y-30.283 Z-22.355
Y-30.4 Z-22.072
G0 Z15
M9
G53 G0 Z150
G53 G0 X20 Y20
M30
I'll have to check on my laptop if i can change the configurations and the problem goes away, but apart from that, everything is ok 😉
Thanks again
Message 13 of 15
x3msnake
Greetings Master
What do you need from me in order to add this post to the library?
Message 14 of 15
x3msnake
The last move is intentionally in machine coordinates,
You want the machine to go to a safe and know position before it ends the program.
It is intended as a back to base setting you can set your own final spot by changing the user settings in the post screen
As for the brackets as long as you untick the open NC file in editor it will not try to install brackets
Message 15 of 15
x3msnake
New Update
User  now has the ability to disable ATC for machines with disabled tool warehouse
With the option set to false it will default any tool to T1 to avoid spindle plunge caused by undefined tool offset
// If the user defines his machine as having no ATC > Set default tool to T1
    if (properties.hasAutomaticToolChange)
        var validateToolNumber = tool.number;
    else
        var validateToolNumber = 1;
	if (isFirstSection()||(tool.number != getPreviousSection().getTool().number)) // Skipping posting instructions when the new operation is using the same tool number
		writeBlock(tFormat.format(validateToolNumber), mFormat.format(6), mFormat.format(table_vacum), mFormat.format(tool_direction),sOutput.format(tool.spindleRPM));
https://github.com/X3msnake/Ouplan-CNC-Fusion-360-Post-Processor/blob/master/ouplan.cps
