Hi i have a question!
I tried using "3D adaptive clearing" to clear out the material on the curved surface of the chair leg design.
But the result always ended up like this:
the highest point of the model is also the top of my stock.
I tried using "Contour", "Parallel", "3D pocket" operations for this part but the result is always the same. The bit will cut about 2mm below where i wanted it to stop.
Bit i used: 8mm Flat-end mill.
Appreciate if anyone could help me with this problem 🙂 thanks!
