No path in Radial
No path in Radial
ian1196
No path in Radial
ian1196
I have tried several variations to cut part of a chamfer on a disc. I get, "
No machining boundaries". What am I missing?
a.laasW8M6T
Theres a few things causing it to fail
  • The outer limit in passes was set to 6.25 in, but the OD of the part is 24 in so I set it to 25 in
  • The tool containment needs to be set to "tool center on boundary" you need to check contact point boundary and set the additional offset to "-tolerance"
Andrew Laas
Senior Machinist, Scott Automation
