no data for post processor
ledhobby
Observer Observer
ledhobby
Observer
Observer
I am able to make a cut file and simulate for the project, but when I open the post processor tab it shows no data. there are no machines available. no library, no post and no options. I am using a hobby account and attempting to use a 3018 machine for the first time.
sutherland-
Hi @ledhobby
Is your F360 up to date?
Have you tried restarting F360 and then logging back in?
Alternatively, you could try to follow those links to see if it helps:
  1. How to install a cloud tool library in Fusion 360
  2. Local tool library is missing from Fusion 360 after a factory reset
Please click on Accept Solution so other community members can see how to solve the issue.
Also, consider giving a Like to the comments that you feel helped you.
Best regards,
Level  sutherland-
Member
ltomuta
It is weird that the posts library is empty, there should always be some posts installed with Fusion. One possible workaround: Preferences -> Preview -> enable the "automatically get lasted" feature.
Just remember that you did this. In some cases you may want this feature to be off.
ledhobby
Observer
Observer
Ok automatically get lasted was checked already. I un checked it and then my machine list appeared. Now when I go to post process I get a list but it doesn't look like what I'm seeing come up on YouTube videos. I have a genmitsu 3018 prover. Can you recommend how I would go about choosing a post that will work with my machine?
ledhobby
Observer
Observer
I am not seeing this screen. I only see a screen asking to choose a post
ltomuta
You are seeing a new UI for basically the same thing. In that old dialog the first fields at the top are dealing with the same thing, choosing a post from one of the locations where posts are installed/saved.
You should be able to find newer tutorial on YouTube to show you how to work with NC Programs. Or in Fusion's documentation.
