Newbie Cam Question
Hi guys, I am looking for a bit of help regarding a problem I'm having. I am trying to cut out a small cavity on a curved surface, and find that I am always cutting it on the outside where I need to be on the inside. I have tried lots of tools and also used the tool containment set to inside boundary. To be fair I may not be using the correct tool (I have tried 2d contour and project both have the same issues) I have even tried to make a face to cut around and also tied to split this face and do 2x 2d contours (cant use a 2d contour as it will bottom out on the shank of the 2mm bit I'm using)
Thanks in advance
