New nagging warning
New nagging warning
ltomuta
Advisor Advisor
New nagging warning
ltomuta
I create one NC Program per setup. So basically use NC Program as a better way of using the good old Post, with remembering output path and file name but not using any of the advanced setup mixing features.
I also right click on the NC Programs root item in the Browser's tree to issue a Post Proces command on all my NC Programs at once to make sure that they are up-to-date. Since the last update, I get this:
This may be helpful for some but not for me. My NC Programs are supposed to be having different WCS settings but they don't ever overlap (one setup/program). Seeing this does not help me. Seeing this every time is annoying.
ltomuta
Nevermind, this was actually and error on my side. Somehow one of my NC programs ended up having two setups merged in it and in that context the warning makes sense.
Maybe the message could be a bit more clear on where the issue is though. If it would said "NCProgram1 has multiple setups with different WCSs" maybe I would have seen where the problem is a bit sooner. Then again, maybe not 🙂
