Need Help Set View to CNC WCS
I have a compound CNC work  cord system set and I want to save a WSC view of it.
Basically (( Set view to wcs  ))
Can this be done in Fusion 360 ?
seth.madore
Orient the part how you wish, right click on the toolpath and select "New Named View":
Seth Madore
I know how to make a view name.
That is not the question thank you.
The question was make the view perfectly straight to the WCS.
Take your work WCS put it on a 2 compound angels now how do you set the screen so that Z is straight out X horizontal that is the view I want to save.
Not sure how to get a perfectly lined up view to WCS?
seth.madore
Create a plane at the orientation you want.
Select that plane.
Click this button:
Create a named view, or use "Set current view as":
Seth Madore
