NC Program
NC Program
ashwin_sWGYU
NC Program
ashwin_sWGYU
I have been using powermill recently shifted to fusion 360
in powermill I used to create individual nc program in one click for all toolpath
in fusion I need to click on individual toolpath go to process which is very time consuming if I have more than 4 tools
Any solutions please
seth.madore
Select the toolpath(s) you wish, right click and select "Create NC Program". You can also just select the Setup and then do the same steps
Seth Madore
programming2C78B
click on the setup folder, then post.
Please click "Accept Solution" if what I wrote solved your issue!
akash.kamoolkar
@ashwin_sWGYU you can select a setup or multiple toolpaths, right click and select "create NC program". that way all those selected toolpaths will be post processed at once and you can save that selection as well.
Akash Kamoolkar
Software Development Manager
ashwin_sWGYU
I click on setup to create nc program but by default it puts all toolpath
in ATC which I don’t want
seth.madore
Clicking on the Setup and creating an NC program will put all the toolpaths of the Setup in there.
Selecting individual toolpaths and then doing the same will create an NC Program with just the selected toolpaths.
Seth Madore
