Hi @chris_ehlen
Fusion is not outputting in any NC Format.
It is generating an intermediate file, which is passed to the post processor engine. Then the engine, with the help of the post script, will generate code, that is specific to a controller.
That's why we have posts for Fanuc, Siemens, Heidenhain, Mazak, as they use different commands, codes and options.
If we had a Sied Meyers post available, it would have been the solution.
But actually such a post does not exist.
So, you can either create one yourself, or ask one of our partners to create a post for you.
When you are looking for a post, or post modifications, you can contact one of our partners.
Given our partners can provide more localized support, we would encourage you to investigate the partners in your area, which can be done through our Services Marketplace.
https://servicesmarketplace.autodesk.com/providers/service-speciality/post-processing
If you need technical documentation for tuning your own post, please take a look at this faq, with links to several resources. From Post processor manual to specific explanations look at :
https://forums.autodesk.com/t5/hsm-post-processor-forum/technical-faq/td-p/7473258
Regards.
______________________________________________________________
If my post answers your question, please click the "Accept Solution" button. This helps everyone find answers more quickly!
