Nc code generating error from Fusion 360 cam after update
armedfabrications
Message 1 of 8
armedfabrications
Hi everyone I'm looking for help on,
A problem that occurred after the latest update.
Error happens when running a 2d contour with a pattern,
doesn't happen with other processes (engrave, drill)
when patterning jobs for batch work with a 2d contour , the NC code same to through a error code, as seen in this screen shot from our hand controller.
the simulation works fine but when runs throws a error 303 ( 303 BoundaryErrorMinusY
This is an operational or file creation error. There is no electrical or mechanical problem with the
machine. Do not replace parts or service the machine.
This error occurs during the job verification process. Job verification checks the job and ensures that the
job will actually fit on the machine and not try to hit any of stops or limits.
This error is generated if the machine is trying to move too far in the negative Y direction and the
carriage will hit the minus Y stops. This error can occur if the NC file has minus Y commands and the
machine origin is not moved far enough away from the Y stops.
This error is more common in dual Y or dual Z machines because the Y range of the machine is reduced
and the mechanics of the machine do not allow all the tools to reach all of the machine’s surface area.
The activity log provides extensive detail on exactly which part of the code has failed and should be
reviewed when trying to sort out the problem.
If you require further assistance please contact AXYZ customer service and obtain a service ticket. An
activity log from your machine as well as the file you are having trouble with will be required to assist
engineering personnel help you with your file problem. )
Only seams to happen since the latest update . need help sorting it as its hurting production big time.
Replies (7)
Message 2 of 8
Joshua.Aigen
Hi @armedfabrications, Could you please export the file and the nc code for us to take a look at, I understand if you cannot. What machine are you running on?
Joshua Aigen
Workshop Supervisor
Message 3 of 8
armedfabrications
Nc code :
:O1009
(Machine)
( vendor: Autodesk)
( model: Generic 3-axis)
( description: This machine has XYZ axis on the Head)
(T2 D=4 CR=0 - ZMIN=-0.2 - flat end mill)
N10 G90
N11 G17
N12 G21
(2D Contour9)
N13 T2
(up cut 4.76mm alloy)
N14 S18000 M3
N15 G0 X193.4 Y66.8
N16 Z18
N17 Z8
N18 G1 Z2.4 F500
N19 G19 G3 Y67.2 Z2 J67.2 K2.4
N20 G1 Y67.6
N21 G17 G3 X193 Y68 I193 J67.6
N22 G1 X47
N23 Y27
N24 G2 X43 Y23 I43 J27
N25 G1 X27
N26 G2 X23 Y27 I27 J27
N27 G1 Y93
N28 G2 X27 Y97 I27 J93
N29 G1 X193
N30 G2 X197 Y93 I193 J93
N31 G1 Y72
N32 G2 X193 Y68 I193 J72
N33 G3 X192.6 Y67.6 I193 J67.6
N34 G1 Y67.2
N35 G19 G2 Y66.8 Z2.4 J67.2 K2.4
N36 G0 Z8
N37 X193.4
N38 G1 Z1.4 F500
N39 G3 Y67.2 Z1 J67.2 K1.4
N40 G1 Y67.6
N41 G17 G3 X193 Y68 I193 J67.6
N42 G1 X47
N43 Y27
N44 G2 X43 Y23 I43 J27
N45 G1 X27
N46 G2 X23 Y27 I27 J27
N47 G1 Y93
N48 G2 X27 Y97 I27 J93
N49 G1 X193
N50 G2 X197 Y93 I193 J93
N51 G1 Y72
N52 G2 X193 Y68 I193 J72
N53 G3 X192.6 Y67.6 I193 J67.6
N54 G1 Y67.2
N55 G19 G2 Y66.8 Z1.4 J67.2 K1.4
N56 G0 Z8
N57 X193.4
N58 G1 Z0.8 F500
N59 G3 Y67.2 Z0.4 J67.2 K0.8
N60 G1 Y67.6
N61 G17 G3 X193 Y68 I193 J67.6
N62 G1 X157.011
N63 Z0.8
N64 X149.011
N65 Z0.4
N66 X90.872
N67 Z0.8
N68 X82.872
N69 Z0.4
N70 X47
N71 Y27
N72 G2 X43 Y23 I43 J27
N73 G1 X27
N74 G2 X23 Y27 I27 J27
N75 G1 Y63.781
N76 Z0.8
N77 Y71.781
N78 Z0.4
N79 Y93
N80 G2 X27 Y97 I27 J93
N81 G1 X193
N82 G2 X197 Y93 I193 J93
N83 G1 Y72
N84 G2 X193 Y68 I193 J72
N85 G3 X192.6 Y67.6 I193 J67.6
N86 G1 Y67.2
N87 G19 G2 Y66.8 Z0.8 J67.2 K0.8
N88 G0 Z8
N89 X193.4
N90 G1 Z0.2 F500
N91 G3 Y67.2 Z-0.2 J67.2 K0.2
N92 G1 Y67.6
N93 G17 G3 X193 Y68 I193 J67.6
N94 G1 X157.011
N95 Z0.8
N96 X149.011
N97 Z-0.2
N98 X90.872
N99 Z0.8
N100 X82.872
N101 Z-0.2
N102 X47
N103 Y27
N104 G2 X43 Y23 I43 J27
N105 G1 X27
N106 G2 X23 Y27 I27 J27
N107 G1 Y63.781
N108 Z0.8
N109 Y71.781
N110 Z-0.2
N111 Y93
N112 G2 X27 Y97 I27 J93
N113 G1 X193
N114 G2 X197 Y93 I193 J93
N115 G1 Y72
N116 G2 X193 Y68 I193 J72
N117 G3 X192.6 Y67.6 I193 J67.6
N118 G1 Y67.2
N119 G19 G2 Y66.8 Z0.2 J67.2 K0.2
N120 G0 Z8
N121 Y53.291
N122 G1 Z2.4 F500
N123 G2 Y52.891 Z2 J52.891 K2.4
N124 G1 Y52.491
N125 G17 G3 X193 Y52.091 I193 J52.491
N126 G1 X202.313
N127 Y93.091
N128 G2 X206.313 Y97.091 I206.313 J93.091
N129 G1 X222.313
N130 G2 X226.313 Y93.091 I222.313 J93.091
N131 G1 Y27.091
N132 G2 X222.313 Y23.091 I222.313 J27.091
N133 G1 X56.313
N134 G2 X52.313 Y27.091 I56.313 J27.091
N135 G1 Y48.091
N136 G2 X56.313 Y52.091 I56.313 J48.091
N137 G1 X193
N138 G3 X193.4 Y52.491 I193 J52.491
N139 G1 Y52.891
N140 G19 G3 Y53.291 Z2.4 J52.891 K2.4
N141 G0 Z8
N142 X192.6
N143 G1 Z1.4 F500
N144 G2 Y52.891 Z1 J52.891 K1.4
N145 G1 Y52.491
N146 G17 G3 X193 Y52.091 I193 J52.491
N147 G1 X202.313
N148 Y93.091
N149 G2 X206.313 Y97.091 I206.313 J93.091
N150 G1 X222.313
N151 G2 X226.313 Y93.091 I222.313 J93.091
N152 G1 Y27.091
N153 G2 X222.313 Y23.091 I222.313 J27.091
N154 G1 X56.313
N155 G2 X52.313 Y27.091 I56.313 J27.091
N156 G1 Y48.091
N157 G2 X56.313 Y52.091 I56.313 J48.091
N158 G1 X193
N159 G3 X193.4 Y52.491 I193 J52.491
N160 G1 Y52.891
N161 G19 G3 Y53.291 Z1.4 J52.891 K1.4
N162 G0 Z8
N163 X192.6
N164 G1 Z0.8 F500
N165 G2 Y52.891 Z0.4 J52.891 K0.8
N166 G1 Y52.491
N167 G17 G3 X193 Y52.091 I193 J52.491
N168 G1 X202.313
N169 Y93.091
N170 G2 X206.313 Y97.091 I206.313 J93.091
N171 G1 X222.313
N172 G2 X226.313 Y93.091 I222.313 J93.091
N173 G1 Y63.783
N174 Z0.8
N175 Y55.783
N176 Z0.4
N177 Y27.091
N178 G2 X222.313 Y23.091 I222.313 J27.091
N179 G1 X56.313
N180 G2 X52.313 Y27.091 I56.313 J27.091
N181 G1 Y48.091
N182 G2 X56.313 Y52.091 I56.313 J48.091
N183 G1 X84.12
N184 Z0.8
N185 X92.12
N186 Z0.4
N187 X154.523
N188 Z0.8
N189 X162.523
N190 Z0.4
N191 X193
N192 G3 X193.4 Y52.491 I193 J52.491
N193 G1 Y52.891
N194 G19 G3 Y53.291 Z0.8 J52.891 K0.8
N195 G0 Z8
N196 X192.6
N197 G1 Z0.2 F500
N198 G2 Y52.891 Z-0.2 J52.891 K0.2
N199 G1 Y52.491
N200 G17 G3 X193 Y52.091 I193 J52.491
N201 G1 X202.313
N202 Y93.091
N203 G2 X206.313 Y97.091 I206.313 J93.091
N204 G1 X222.313
N205 G2 X226.313 Y93.091 I222.313 J93.091
N206 G1 Y63.783
N207 Z0.8
N208 Y55.783
N209 Z-0.2
N210 Y27.091
N211 G2 X222.313 Y23.091 I222.313 J27.091
N212 G1 X56.313
N213 G2 X52.313 Y27.091 I56.313 J27.091
N214 G1 Y48.091
N215 G2 X56.313 Y52.091 I56.313 J48.091
N216 G1 X84.12
N217 Z0.8
N218 X92.12
N219 Z-0.2
N220 X154.523
N221 Z0.8
N222 X162.523
N223 Z-0.2
N224 X193
N225 G3 X193.4 Y52.491 I193 J52.491
N226 G1 Y52.891
N227 G19 G3 Y53.291 Z0.2 J52.891 K0.2
N228 G0 Z18
N229 G17
N230 G28
N231 M30
Message 4 of 8
armedfabrications
It on a muticam router, running axyz controller.
Message 5 of 8
armedfabrications
Please find the file , if other ways of sharing it please let us know
Message 6 of 8
hyperbolicindustries
File>Export>*.f3d and attach to reply using the little paperclip icon.
Message 7 of 8
armedfabrications
try that
Message 8 of 8
armedfabrications
I have found the problem,
So the only thing causing this issue is the lead in an lead out.
Once turned off problem solved.
Fusion360 that's where your bug is.
