NC Code Failed to Post? Works until I add a SWARF Milling routine.
Trying to get the post processor working for multi axis for use with our  Hurco VMX42srti Mill.  Manufacture program works fine until I add a swarf routine.  Get the following error code file. Any help would be apprecitated.
Information: Configuration: HURCO 3D
Information: Vendor: HURCO
Information: Posting intermediate data to 'C:\Users\Woody\OneDrive\Documents\1003.hnc'
Error: Failed to post process. See below for details.
Code page changed to '1252 (ANSI - Latin I)'
Start time: Tuesday, September 7, 2021 5:41:58 PM
Code page changed to '20127 (US-ASCII)'
Post processor engine: 4.5793.0
Configuration path: C:/Users/Woody/AppData/Local/Autodesk/Autodesk Fusion 360/CAM/cache/posts/hurco3d.cps
Include paths: C:/Users/Woody/AppData/Local/Autodesk/Autodesk Fusion 360/CAM/cache/posts
Configuration modification date: Wednesday, September 1, 2021 5:20:09 PM
Output path: C:\Users\Woody\OneDrive\Documents\1003.hnc
Checksum of intermediate NC data: 042fb7d65a80a303a1c4d2b00e5cb42d
Checksum of configuration: 7a249207f36aeb82511a6b3724f0f490
Vendor url: http://www.hurco.com
Legal: Copyright (C) 2012-2021 by Autodesk, Inc.
Generated by: Fusion 360 CAM 2.0.10813
Error: Error: Section.getInitialToolAxisABC() is not allowed for section.
Error at line: 1
Error in operation: 'Swarf3'
Stack dump:
("Section.getInitialToolAxisABC() is not allowed for section.")@:0
onSection()@C:/Users/Woody/AppData/Local/Autodesk/Autodesk Fusion 360/CAM/cache/posts/hurco3d.cps:888
Failed while processing onSection() for record 97957.
Error: Failed to invoke function 'onSection'.
Error: Failed to invoke 'onSection' in the post configuration.
Error: Failed to execute configuration.
Stop time: Tuesday, September 7, 2021 5:41:58 PM
Post processing failed.
daniel_lyall
4, 5, or 6 axis machine?
The file will need to be looked at with its post as well, the error is saying A, B, and C what is in on section.
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
OK i will have a look thanks for your help. .  I think part of the problem also is that I was selecting a guide line that was not part of the correct path.
