I need to make fret slots into a guitar fretboard. The slot width is 0.6 mm and the tool diameter is also 0.6 mm.
The Depth of cut is set to 0.25 mm and the Ramp type to Plunge.
2D Pocket produces a toolpath where the tool comes out of both ends of the open slot, but even if Both ways is selected in Passes, plunging down happens only at one end of the slot, so the tool travels back and forth at the same depth. This doubles the machining time.
Slot produces a toolpath where plunging happens at both ends of the slot, but the tool stays inside the slot boundaries, so this toolpath does not clear the ends of the open slot. For this to happen the tool would need to move further, come out of the ends of the slot.
How could I:
- Make 2D Pocket plunge down at both ends and so machine both ways, cutting the machining time to half?
- Make Slot move the tool further, out of the ends of the open slot, so that the slot will be opened up all the way from end to end?
