N Sequence number to match tool number
macr72515SL4L
macr72515SL4L
Hi all,
Can someone please assist me on PP so that the N sequence number matches the tool number
and increments every time the tool is being called.
Example:
N0101
T1 M6
N1201
T12 M6
N0102
T1 M6
N1202
T12 M6
Accepted solutions (3)
da_fish
This will do what you are looking for:
function writeCommentSeqno(text) {
  if (toolSequenceNumbers[tool.number] != undefined) {
    toolSequenceNumbers[tool.number]++;
  } else {
    toolSequenceNumbers[tool.number] = 1;
  writeln(("N" + ((tool.number * 100) + toolSequenceNumbers[tool.number])) + " " + formatComment(text));
Some where in the beginning of your post you'll have to declare the variable:
var toolSequenceNumbers = {};
If you replace your writeCommentSeqno() function with the code it should work just fine. If you need more help integrating this logic into your post let me know.
macr72515SL4L
Thanks @da_fish! That worked really well on my post for Okuma mill but can't make it work on the Makino posts.
Somehow the Makino post has different N sequencing format.
da_fish
You're welcome I'm glad it worked!
I looked at a Makino post that I got off the library and it certainly has a different code format for outputting sequence numbers. I'll be away from my desk most of the day tomorrow so I'll look into it more and try to get back to you later tomorrow are the next day.
macr72515SL4L
Thanks! will be much appreciated. ; )
da_fish
@macr72515SL4L, Find the writeToolBlock() function which should look like this:
function writeToolBlock() {
  var show = getProperty("showSequenceNumbers");
  setProperty("showSequenceNumbers", (show == "true" || show == "toolChange") ? "true" : "false");
  writeBlock(arguments);
  setProperty("showSequenceNumbers", show);
And replace it with the following code:
  var num;
  if (getProperty("showSequenceNumbers") == "toolChange") {
    } else {
    num = "N" + ((tool.number * 100) + toolSequenceNumbers[tool.number])
  writeBlock(num, arguments);
 And don't forget to declare the variable somewhere towards the beginning of your post:
If the Show Sequence Numbers property is set to "Only on tool change" then it will output the special N numbers, otherwise it will post normally.
I hope this works for you!
macr72515SL4L
Thanks @da_fish! It's working well. Appreciate your help.  👍
