N Line numbers not showing in G-code post
stylz67
Message 1 of 1
stylz67
I always use the N line numbers when doing a post.  It worked fine yesterday, when I look at saved files from then, but for some reason today when saving a post, there are no N(number) showing after the initial 11 lines (mine set at 10, 15, 20, 25 etc. up to 60) then quits showing.  I have used the typical POST PROPERTIES/ FORMATS/ USE SEQUENCE NUMBERS and have it set to YES.  I tried switching to NO and ONLY ON TOOL CHANGE, then back again and all 3 look identical.  Even the NO choice gives me Ns 10 through 60 showing, same as with ONLY ON TOOL CHANGE.  I've closed and reopened Fusion with same results.
Thanks for help in advance.
Replies (0)
