My Z axis is posting to deep
Message 1 of 8
I am new to Fusion 360 and using the manufacture workspace. I am writing tool paths to test on my CNC machine. Just starting with some simple line and splines. Using the trace cut in 2D, cutting on a plane. The cut is going 1 mm deeper into the material. I have looked into the tool setup and can not find what is causing this. In the post, in the tool description line; (T1 D=6.36 CR=0 – ZMIN=-1 flat end mill) and in the start of the code the line G1 Z-1 F500. If I manually edit these values to O the cutter is correct to where it was zeroed out to. But any time there is a z retract it need to be edited. What setting am I missing or change in the process need to be made? I have not tried on a 3D cut yet to see if the Z is off yet. Need some help to figure this out
PS the Post Processer is RichAuto if the helps
Replies (7)
Message 2 of 8
johnswetz1982
Go File>Export>*.f3D and attach your file in a reply. It will make it easier to diagnose what is going wrong.
Message 3 of 8
Thank you for helping!
Message 4 of 8
Trigg3r
Looking at your file, the posted code is correct. Your selected contour to trace is 1mm below your Co-ordinate Z0 which is set to a stock box point at the top of your defined stock.
EG : You zero your Z axis on the top of the stock material and you have selected a profile to trace 1mm below that zero.
What depth of cut were you trying to achieve ?
Message 5 of 8
In setup, because you don't have a model, you select a sketch instead, that clears yellow flag.
In operation, tool follows selected sketch, if you want to raise the tool, use "Axial Offset".
2019-10-06 16_12_31-Autodesk Fusion 360.png2019-10-06 16_18_41-Autodesk Fusion 360.png
Message 6 of 8
Thank you for your help, that was it! I set one at zero and it road on the plan and one at 5mm and it cut at that deep. Thanks for your time
Message 7 of 8
jlucasemail
I've also had problems figuring out the Z settings!
Personally I now find it easier to read Top Height and Bottom Height as top and bottom of cut.  I then reference Top Height (cut) to a selected face used to zero the tool Z. The Bottom Height is then referenced to the depth of cut below the Top Height.
Since I have a hobby mill I have to zero the Z axis after every tool change so this method is easier for me.
Message 8 of 8
Trigg3r
@Anonymous Glag you got it sorted.
Please mark this post as a solution so others may find it.
Cheers.
