Multiple WCS in CAM patterns
hausen00
hausen00
I am trying to machine the same part multiple times in one run. I use the add to new pattern - linear and create multiple instances. Can I assign a different WCS to each of the instances and if yes, how.
LibertyMachine
To use Multiple Work Offsets, you can create that in the Setup, rather than using Pattern. I don't believe Pattern will allow multiple WCS output, although it's been requested
Seth Madore
Owner, Liberty Machine, Inc.
Good. Fast. Cheap. Pick two.
hausen00
Thanks a lot, that totally met my needs. With that feature you dont even need to pattern.
CBB1962
I ran into an issue using multiple WCS and setups with patterns that have multiple tools.  I chose "order by tool" in the pattern and "order by tool" in the Multiple WCS, expecting that it would process as follows:
WCS1 - Pattern - Tool 1,
WCS2 - Pattern - Tool 1,
WCS3 - Pattern - Tool 1,
WCS4 - Pattern - Tool 1,
WCS1 - Pattern - Tool 2,
WCS2 - Pattern - Tool 2,
WCS3 - Pattern - Tool 2,
WCS4 - Pattern - Tool 2,
WCS1 - Pattern - Tool 3,
WCS2 - Pattern - Tool 3,
WCS3 - Pattern - Tool 3,
WCS4 - Pattern - Tool 3,
Three Tool Changes...
It does not process that way, It processes:
16 Tool Changes!!!
16 vs. 3 that's a lot of wasted movement and time.
I worked around this but it would sure be nice if "order by tool" in the Multiple WCS did what it said.  Is there a way to fix this?
After generating an NC file, you can goto the operations tab of it and click the checkbox for re-ordering tools to minimize tool changes.
