Multiple WCS, few parts with same program
Hello there,
I have question about WCS, how to set 3 WCS to cut 3 parts. Also you can help if it is posible to do that with only 1 WCS that will be great.
Marco.Takx
Hi @Anonymous,
Make a Setup with all your operations.
Select all the operations and put them in a Linear Pattern.
So you need only one WCS.
Keep in mind that you Make:
  • the Spacing (lenght product + Width Cutting tool + ...)
  • Operation Order -> Preserve Oder
If my post answers your question Please use  Mark Solutions!.Accept as Solution & Give Kudos!Kudos This helps everyone find answers more quickly!
Met vriendelijke groet | Kind regards | Mit freundlichem Gruß
Marco Takx
CAM Programmer & CAM Consultant
Did you have any idea how can i share my program / drawing and nc file with you so you can check that everything is ok? Not for tools but for order of operations. Thank you in advance
Marco.Takx
Hi @Anonymous,
Can you share your model so one of us can take a look at it?
Marco Takx
Thank you Marco you are really helpfull to me.
https://a360.co/2SoDFyL
Marco.Takx
Hi @Anonymous,
Basically is correct.
Only the distance of 12 mm is I think to large.
I've changed it to 9,5 mm.
Marco Takx
