Multiple Setups with Multiple work offsets
chris_IgniteDigi
chris_IgniteDigi
Hi All,
I regularly post multiple setups to a single file to run, either using the work offset iteration in the setup tab, and by selected multiple setups in the tree.
Today however I found an odd behaviour, where if I have one set-up with multiple iterations (in this case G56 and G57) and a different setup up to run a G55. The post processed file did not include the code for the operations to be carried out at G57.
The attached picture shows the two setups highlighted that I posted simultaneously.
Is this a glitch in fusion or a glitch in how my post processor handles this?
Cheers
balsmen
Hi @chris_IgniteDigi,
Sorry you're having this problem. I'm not totally clear why the problem is happening just from your message.
Would you be able to attach that file to this post so I can take a closer look at what might be going on. Also what post processor are you using - one that comes with Fusion, or a modified post?
To attach the file, go to File->Export...->Save to My Computer and save it as a Fusion Archive (*.f3d) file. Then attach it to your reply here.
Noah
Noah Balsmeyer
Fusion Mfg Software Engineer
