Multiple Plasma Cutter Machines?
Torquindsl
Torquindsl
I have questions about adding my plasma cutter tool in the Machine Library. In the library I see that I can define things like max feed rate in a machine. I assume this means max feed when cutting a part. For a plasma cutter, this number differs, depending on material and thickness. I would think this would also be true for a mill, as those attributes and the individual cutter specifics being important to max feed rate value also. To be accurate and use F360 to the fullest, should I be defining a different machine for each material and thickness that I am cutting?
Does that make sense?
Will these settings benefit me to store in the Machine settings?
Also, when defining a machine, I see that there are "kinematics". When defining kinematics it has 3 axis, a table, and head sections. Do I define all of those?
In what situation would I change the orientation for any of these axis using the "orientation" drop down?
What should I be choosing in the "Coordinate" drop down for each axis?
All of the docs I have found on "kinematics" only talk about machine simulation, so I am now wondering if this machine definition only applies to a simulation. Can someone clarify this?
Is there documentation I have not found that explains all of these options?
Chris
a.laasW8M6T
Hi
  • To be accurate and use F360 to the fullest, should I be defining a different machine for each material and thickness that I am cutting?
         No you do not need a machine for each material, that is handled by the cutting presets in the tool library:
You can add multiple presets here for different materials/thicknesses
In reality you do not actually need a machine, with defined kinematics for a 3 axis machine at all, especially not for a plasma.
You don't even need to select a machine in your setup.
Where a machine comes in useful is for multi axis milling machines, for defining kinematics and for machine simulation.
You also must use a Machine for Additive processes.
Hope that makes sense, I think the fact that in a setup you can select a machine leads many users to believe that you HAVE to select one, but that is not the case
Andrew Laas
Senior Machinist, Scott Automation
Torquindsl
So, is it wise to set up different tool presets for a plasma cutter?
Will I still need to select a machine to apply the tools/presets, or can I use the tools/presets without selecting a machine? I do not recall anything about selecting a preset anywhere in the setups I have created.
Chris
a.laasW8M6T
You don't need a machine to select presets
Check this short video out:
(view in My Videos)
Andrew Laas
Torquindsl
Definitely helpful. Thank you fro taking the time to create the video. It helps a lot.
Chris
