MULTIPLE MDF DOORS FROM ONE MODEL
1david7
1david7
HI,i have a mdf door model, its component with parameters, width and height, and only this parameters are changeing depends what dimenssion of door i need (patern on the door always the same) How to speed up cutting multiple doors with difrent dimensions (width,height),with same patern only width and height change ? using one model, now its make me crazy to make every component for each dimensions... and copy each component with difrent size and paste to to mdf board could u Help ??
AND I know this is very advanced, is there any way to make toolpath for one kind od mdf door patern and then just click every single door with difrent dimension(width,heinght) but the same pattern inside...
engineguy
@1david7
Not exactly sure of what you mean by "the pattern is the same on all doors", surely if the pattern is always the same it won`t fit on some sizes of doors ????
If you want to just have everything the same relative to the outer dimensions of the new door then just scale the whole thing and it will be exactly the same only a little larger or smaller as required.
If you want the patterns to stay at a static size and just the outer dimensions of the door to change then save the patterns out as individual Documents and just have Blank door(s) that you can open and then merge(insert) the pattern into it, all really simple and only requires a little forethought when creating the patterns/doors etc.
As above, not hard, don`t need some "magical" modification to Fusion from what I can tell from your Post 🙂 🙂 🙂
Stay Safe
Regards
Rob
daniel_lyall
You can do toolpath templates.
It would help to see your model To attach a file Go to File -> Export and save as a .F3D Archive File and attach it to your next post, if you can not post the file you can PM it to me or say in your next post you can not post the file and one of the Guys that do NDA work will help.
I think it can be done but I would need to see the model to see if what I think would or would not work.
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
1david7
Here is model
Pabiuro
Hey Daniel,
I'm also facing same problem. Where I can find your solution?
