Hi all!
I play around with the Multi-Axis Finishing operation with "Circle segment taper" tool.
I try a very simple model and can't get a toolpath that make sense!
1. I setup a stepdown with 7mm. As you can see Step down is good with 7mm, but the first step down is something, yeah I would say stupid.
Fun fact! If I change stepdown to 0.5mm ... more stupid...
2. then the way in which the toolpath is created. In the tooltip the toolpaths are nicely down to the floor
But the toolpath that was created is completely unsatisfactory
How you can see in the next picture (it shows the last cut), the toolpath is absolutly confusing!
- The pathes are nonsensical
- The wall is not processed to the possible depth
I assume that the fault is in front of the PC, which is always a good starting point!
Whatever I've tried so far, I can't get the toolpath any further to the floor or a nice simple toolpath!
And one more hint. I am aware that it could be done differently, but that is not the issue here. I'm only interested in the operaion itself!
I look forward to your tips on what I am doing wrong!
