Moving Speed between 2 contour chains
sergio.prodi
sergio.prodi
How do I speed up the moving speeds between work paths
I have first drill then 2d Contour with 2 chains. The movement from end position drill to begin position 2 contour is ok (could be faster).
But the movement from end position chain 1 to begin position chain 2 is really slow. Where do i set the speed?
Thanks all 😉
seth.madore
There is a Transition Feedrate that you can set:
A move between a drilling toolpath and a 2D Contour (or any other toolpath) should be done in rapid moves. If that's not happening, I'd like to see your file and post processor. Are you using a Personal Account? If so, rapid moves are not possible.
Seth Madore
sergio.prodi
Yes i'm using a personal account.
My transition feedrate is set to 300mm/min an now i think about it that is indeed very slow. It's the same as my cutting feedrate.
So I could probably double that easely? I'm I right? roughly calculated your settings are like a 1000mm/min
Thanks for the answer, really appreciate it
programming2C78B
your transition rate should basically be your rapid feed if the tool isnt in contact with any material.
Please click "Accept Solution" if what I wrote solved your issue!
seth.madore
A warning though; we don't run collision detection on transition moves, it's incumbent on the programmer/machinist to verify that transition moves don't link through stock/part.
Seth Madore
