Move manual NC post location.
ELAFING
Message 1 of 8
ELAFING
Capture.JPGIs it possible to have the manual nc operations post in the location marked by the arrow. I would like to use a program stop followed by a comment and have them post in the middle of operations instead of posting before the Z0 in the previous tool path. Does that make sense.
Replies (7)
Message 2 of 8
johnswetz1982
Yes, *if* your post processor supports pass through statements. Which on are you using?
Message 3 of 8
ELAFING
Haas pre ngc post.
I have enabled pass through in the post.
My issue is the location of the pass through code, I want it after the Z0 from the previous op.
Currently posting like this,
N130 M9
N135 g0 g90 g28 y0        this is the pass through code location
N140 m00                                  so it this
N145 M5
N150 G53 G0 Z0.
I want the manual nc selections to post here.
In between the operations and after the G53 G0 Z0 line
(2D Adaptive3)
(Rough pocket +.020 radial & Axial)
N155 M1
N160 T15 M6
N165 S5000 M3
Message 4 of 8
If you are talking about placing manual NC command or comment in particular place .....
When you define your manual NC command or message, it ends up on the end of all operations in column.
You then click on it and while holding down mouse button, you drag it in above operation of you choice, when green line appears between desired operations, you let go of the mouse button, when you post, action or message contained in manual NC should appear where you intended.
Message 5 of 8
daniel_lyall
Do you want it to be permanent you can add that into the post at the location where the G53 is?
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
Message 6 of 8
ifuASTJY
Hi, I am interested in that too for my Sinumerik 840 D pp.
Normally you would want a program STOP after Z retract so you can check/ or measure part.
Thanks!
Message 7 of 8
boopathi.sivakumar
@ELAFING
Search for this line
if (hasParameter("operation-comment")) {
and paste the COMMAND_PASS_THROUGH;
command above
like this
    if (forceResetWorkPlane && newWorkPlane) {
      forceWorkPlane();
      setWorkPlane(new Vector(0, 0, 0)); // reset working plane
    var comment = getParameter("operation-comment");
And remove any other command_Pass_through if you use while copy the code
Boopathi Sivakumar
Principal Technology Consultant
Message 8 of 8
ifuASTJY
@boopathi.sivakumar  it will post as last line in the operation if I don't have a tool change next.
If I have a tool change it is still before writeRetract.
