Announcements
Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
Minimum Cutting Radius: This value should be smaller than the tool radius
landcrush
landcrush
I'm trying to set up a laser tool. I created the tool and just used the default values. I just want to know if fusion will output correct G-Code to set the power and feed rate, however, I can't get the tool set up as I always get this error. The setup is simple, a square with a 2-d contour. There does not seem to be anyplace to set the tool radius to a different value that I can find. How can I eliminate this error message and continue with the setup?
Thanks in advance for any help.
seth.madore
You cannot use the 2D Contour toolpath for a laser, as that is a Milling toolpath. You need to use the 2D Profile toolpath in the Fabrication section (your Setup also should be set to "Cutting". See photos below:
Seth Madore
landcrush
Thank you my friend, the video I was watching did go into this, but I was just too impatient to get started to watch it thoroughly. This is exciting stuff. Thank you for taking the time to help me.
Kind regards,
Jerry
