Hello
Facing down a part in the subspindle, depending on which post I use the Z axis moves are either correct or the same as the main spindle.
It seems the Hass ST30 SSY, Seimens Mill Turn and Takisawa Fanuc all post Z values the same as main spindle. ie Z7.0
All the others I have tried post correctly ie the Doosan, Nakamura... ie Z-7.0
All posts were downloaded fresh on the 10th June 2020. The cam setup must be correct for some to work so I must conclude that it is a post issue. Any clues?
The one I need to get working is the Siemens Mill Turn
I have attached some simple posted files for reference.
Steve
