Millturn Post Secondary Spindle Z values in the wrong direction
steve.evans
steve.evans
Hello
Facing down a part in the subspindle, depending on which post I use the Z axis moves are either correct or the same as the main spindle.
It seems the Hass ST30 SSY, Seimens Mill Turn and Takisawa Fanuc all post Z values the same as main spindle. ie Z7.0
All the others I have tried post correctly ie the Doosan, Nakamura... ie Z-7.0
All posts were downloaded fresh on the 10th June 2020. The cam setup must be correct for some to work so I must conclude that it is a post issue. Any clues?
The one I need to get working is the Siemens Mill Turn
I have attached some simple posted files for reference.
Steve
Marco.Takx
Hi @steve.evans,
I advise contacting your Local Reseller in the link below how can help you.
HSM post adjustments needed? Find your right contact here.
If my post answers your question Please use Accept as Solution & Kudos This helps everyone find answers more quickly!
Met vriendelijke groet | Kind regards | Mit freundlichem Gruß
Marco Takx
CAM Programmer & CAM Consultant
