Millturn Post Modification, needing some assistance
Message 1 of 10
Hi. I was hoping somebody could help me with modifying a post, I was wanting to insert a G4 X1. into my post for a short dwell between C axis locking and unlocking commands. I am very new to post processors and do not want to do something I should not. Thanks
Replies (9)
Message 2 of 10
seth.madore
What is the post processor?
This is a very easy change to implement, especially with the Visual Studio add-in that Autodesk released a while back
Seth Madore
Message 3 of 10
Hi Seth thanks for the reply. It is the Takisawa millturn post with Fanuc controller. I also did setup the visual studio code and have successfully been able to alter some things to work for me , just mainly M code alterations but nothing like adding in new lines of information. I’m still trying to get my head around understanding how to read the format properly.
Message 4 of 10
seth.madore
Using Visual Studio and the add-in developed by ADSK, find these lines, they should be around 10738 and 1083, assuming stock Takisawa post:
onCommand(COMMAND_UNLOCK_MULTI_AXIS);
onCommand(COMMAND_LOCK_MULTI_AXIS);
After each one of them, you can insert: writeBlock(gFormat.format(4),("X1."));
This will give you code that looks like this:
M74
G4 X1.
G0 C125.
M73
Adjust the "X1." to your desired time, where "X" is in seconds
Complete edit:
Seth Madore
Message 5 of 10
Thanks Seth i have just tried it and have had no success, is there something else i might be missing ?
Message 6 of 10
seth.madore
Well, without knowing WHAT you did, it's kinda hard to say what went wrong. Can you attach the .cps file in your reply so we can see what's what
Seth Madore
Message 7 of 10
This is the file I tried.
Message 8 of 10
seth.madore
Your post is producing this code at unlock/lock commands:
G97 S4000 M70 P12
M74
G4 X1.
G0 C160.
M73
G4 X1.
What's not correct about that?
Mind you, this is the post you attached just now, with no other edits done to it
Seth Madore
Message 9 of 10
Thankyou so much it is working. I was not seeing what you got until i rebooted visual studio code.
Message 10 of 10
seth.madore
Awesome, great to hear!
Seth Madore
