Milltronics Turning processor outputs G3 instead of G2.
nweisz
nweisz
We just acquired a Milltronics ML-15 lathe, and for post we are using the the Fusion 360 provided  Milltronics Turning processor.
When posting a radius move for an outside profile,  the output is reverse from what the machine needs. G3 instead of G2.
If manually edit the NC file, and change G3 to G2 the program runs fine.
Is there a way to change the post output to produce the desired G code?
hyperbolicindustries
Your using a turning (lathe) post processor for a mill?
nweisz
Sorry, I meant lathe. (Corrected)
