Milling pocket aligned with wood grain
lukaspanic
lukaspanic
I am trying to create an operation that is a pocket with the majority cut in x direction only, to align with wood grain. If I use 2D pocket it makes it a bunch of rectangles inside of each other which is too much cutting across the grain. Adaptive clearing is awesome fast and efficient but it is a bunch of swirls across the grain. A facing operation is essentially what I need but within the boundaries of the pocket like in the highly artistic drawing below. I understand that I will have to go at least once around the inside perimeter of the pocket to clean it up and that's ok.
How would I set this up?
  • Help
daniel_lyall
You can use the parallel toolpath to cut like that as you can change its direction and have it inside the boundary basically like a raster toolpath.
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
lukaspanic
That is exactly what I was looking for, thank you! I think I tried it before but got only an error message and an empty path. I guess this time I set it up correctly and it works.
Thank you!
