Milling out knurled surface
mickyfastiggi
mickyfastiggi
trying to find a command to mill out the traction surface, I am using a 90 degree mill bit. what command would I use to just mill those simple shape ?
a.laasW8M6T
Hi
I would use 2d Trace
Pick the bottom of the vees as the contour and use multiple depths if required.
You can apply extensions to the contours if required to get the tool to run on/ off the part
Andrew Laas
Senior Machinist, Scott Automation
