Milling a topo map from .stl
JennayOakHill
JennayOakHill
So I'm working on trying to get our panel router to mill out topo maps from GIS information from USGS. I've managed to get the data into a .stl file which fusion is happy to load up, but I'm at a loss as to how to convert the mesh into a body/if I need to and what machining processes to actually cut the map.
I tried running a morphed spiral with a 0.25" end mill after scaling down the .stl to 24" wide, didn't do much for me.
Link to the .stl file:
https://drive.google.com/file/d/1CoHyL_JW4H2bxIIO-UkF3I6L0LoPKj-g/view?usp=sharing
You dont need to convert it to a body, you can machine directly from the STL using 3D operations. Use a 3D Contour or an Adaptive toolpath then finish with a Parallel or Morphed Spiral. Be sure that you have Stock To Leave in your roughing operation.
JennayOakHill
Will try that in a minute.
JennayOakHill
Failed for reasons other than your answer. It seems that the engineer didn't finish the retrofit of the machine correctly.
Tested the process on a little cheap desktop CNC and it worked a treat, so yeah, the problem is in the machine or the software talking to the machine.
It keeps adding height every time it retracts and rapids to the start of the next cut.
