Mill/Turn Post for Fanuc 21i on a CTX410
Hi All
So with help from @xander.luciano I was able to draw and CAM out a part which has center drilled holes around the the spun axis.
My problem now is that the generic lathe POST for the fanuc give a single line error of '!Error: Failed to post data. See log for details.' I have not been able to find a log and am a little lost as to the steps I need to take to get the POST to under stand the issue.
The online docs form Autodesk indicate a location for the logs on my mac but there not at this location. With out the logs I can do anything to take this process forward.
I need to adjust the output of the post to give me X and Z axis with a C for the chuck.
A M14 turns on control of the C axis for the chuck
M103 and M104 set the direction of the driven tool (CW, CCW)
I'm sure there is more but at this stage I have no idea.
Kudo button - If it resolves your issue, press Accept as Solution!
