I'm new to using fusion for CAM. I've only ever programmed my CNCs manually and am trying some basic models I have to get a bit of experience before moving onto more complex stuff...
I'm trying to mill 6 slots down the length of my turned part. I have a ball nosed cutter that can mill each slot in 1 pass. Can I get the software to machine each slot with one pass? The best I can get is to use the rotary parallel wizard to mill around the entire circumference of the part, wasting a lot of time and code...
I have already machined the OD and some grooves that the slots pass through, but I don't think that should affect it.
Thanks in advance
