merging set ups
merging set ups
adventuremetal
merging set ups
adventuremetal
Is there functionality that would allow me to easily post code that merges the two attached files that are using 2 different work offsets in order to cut down on tool changes?  Previously I've just cut and pasted for the 2 different posts, which works but ends up being tedious especially if there ends up doing a bunch of tweaking to the program.
Roger
LibertyMachine
Depress the CTRL key and select all the Setups you want to post out. (If you only have two setups, you could just select the very top folder and that will select all the Setups)
You will be able to post out everything you have selected. Couple of notes;
1) It will flag you that multiple WCS systems have been selected and that the post needs to be configured. Click "OK".
2) It will perform a G53 Z0 in between operations, even if it's the same tool. This is by design and it will require a post edit to circumvent
Seth Madore
Owner, Liberty Machine, Inc.
Good. Fast. Cheap. Pick two.
adventuremetal
Perfect and I just saw the button to minimize tool changes. Should be making parts in an hour or so now.
Roger
