mazak qtn100m post usexzc
jerry686UC
jerry686UC
Hey
is there a way to always force xzc moves in the post without doing an action command before every  mill operation?
i am using the post from the library
seth.madore
In some cases it can be geometry dependent, if for example, the resulting negative X value is too large for your machine to handle. Also, if your post is setup to allow any negative X output in milling code, you could reduce that value
Otherwise, at the moment, there are no other mechanisms available outside of Action commands.
Seth Madore
jerry686UC
Hey thank you for the reply but the problem is my machine with matrix controller does not have the specific iso options to use g12.1 polar.
so it need to post everything in xzc. i just want to know if there is a solution to avoid to manually input the action command.
