Manufacturing broken
friesendrywall
Message 1 of 27
friesendrywall
Whats all this supposed to mean?
Invalidated: Tool
Invalidated: Tool
Invalidated: Invalidation due to different value for parameter 'tool_type' with level 7.
Invalidation due to different value for parameter 'tool_number' with level 2.
Invalidation due to different value for parameter 'tool_diameterOffset' with level 2.
Invalidation due to different value for parameter 'tool_lengthOffset' with level 2.
Invalidation due to different value for parameter 'tool_compensationOffset' with level 2.
Invalidation due to different value for parameter 'tool_vendor' with level 2.
Invalidation due to different value for parameter 'tool_productId' with level 2.
Invalidation due to different value for parameter 'tool_diameter' with level 7.
Invalidation due to different value for parameter 'tool_fluteLength' with level 2.
Invalidation due to different value for parameter 'tool_bodyLength' with level 7.
Invalidation due to different value for parameter 'tool_overallLength' with level 2.
Invalidation due to different value for parameter 'tool_shaftDiameter' with level 7.
Invalidation due to different value for parameter 'tool_numberOfFlutes' with level 2.
Invalidation due to different value for parameter 'holder_description' with level 2.
Invalidation due to different value for parameter 'holder_productId' with level 2.
Invalidation due to different value for parameter 'tool_spindleSpeed' with level 2.
Invalidation due to different value for parameter 'tool_surfaceSpeed' with level 2.
Invalidation due to different value for parameter 'tool_rampSpindleSpeed' with level 2.
Invalidation due to different value for parameter 'tool_feedCutting' with level 2.
Invalidation due to different value for parameter 'tool_feedPerTooth' with level 2.
Invalidation due to different value for parameter 'tool_feedEntry' with level 2.
Invalidation due to different value for parameter 'tool_feedExit' with level 2.
Invalidation due to different value for parameter 'tool_feedRamp' with level 2.
Invalidation due to different value for parameter 'tool_feedPlunge' with level 2.
Invalidation due to different value for parameter 'tool_feedPerRevolution' with level 2.
Invalidation due to different value for parameter 'finishFeedrate' with level 2.
Invalidation due to different value for parameter 'entry_radius' with level 5.
Invalidation due to different value for parameter 'entry_distance' with level 5.
Invalidation due to different value for parameter 'entry_verticalRadius' with level 5.
Invalidated: invalidateByLevel
Invalidated: Tool
Invalidated:
Invalidated: Tool
Invalidated:
Invalidated: Tool
Invalidated:```
Replies (26)
Message 2 of 27
seth.madore
Wait WHAT???? - Jackie Chan Why? | Make a Meme
Can you share your file?
File > Export > Save to local folder. Return to thread and attach the .f3d file in your reply
Seth Madore
Message 3 of 27
friesendrywall
Ok...
Beta software..
Message 4 of 27
seth.madore
No. It is not Beta Software. Do bugs exist? Yes. Find me one that doesn't. I'm saying this as an actual paying customer, running a full time shop off of Fusion.
I'm looking at your file now, will post back with findings.
Seth Madore
Message 5 of 27
jeff.pek
Where are you seeing that? Can you post a screen shot? In the log window, there's a way to control how much detail is shown. If you have the "debug" button selected, you'll see a lot more than most people would find useful.
Jeff
Message 6 of 27
seth.madore
Where did the problem exist? I brought your file in and regenerated everything, but I get this:
Seth Madore
Message 7 of 27
friesendrywall
Combo 2d Contour8 won't generate properly.  I can't get it to contour a different level at all.
Message 8 of 27
friesendrywall
I have been using this for 3 years.  Too often I come back to something and end up spending hours working around stuff similar.  There needs to be 2 channels, beta, and stable.
Message 9 of 27
friesendrywall
If I have logging enabled, I don't know where it is and how it happened.
Message 10 of 27
seth.madore
I know you've stated in the past, but what OS is your computer?
With multiple contours selected:
Seth Madore
Message 11 of 27
friesendrywall
I can't set the contour height, it errors out.
I'm on Win 7 x64, unsupported yes.
Message 12 of 27
seth.madore
How are you setting it? In the prior image, I set my Bottom Height to "Selected Contours". You had it set to "Model Bottom. Are you trying to select multiple contours on one part or on the adjacent part? It wasn't clear what the desired outcome was to be
Seth Madore
Message 13 of 27
friesendrywall
I have noticed manufacturing acting odd ever since the update where the 'automatically generate toolpath on operating change" checkbox existed.   There is some weird connection between some operations, and some will rebuild and rebuild and rebuild on other operation edits, for no obvious reason.  Even after unchecking them, some of my operations require rebuild at apparently random times.
My point about beta software is that the users end up testing it.  I want software that does the same thing 6 months later, even if it includes bugs.
Message 14 of 27
friesendrywall
I wanted the cut a contour that follows the bottom of the part.  Since there is a chamfer, the easiest way is to simply select model bottom.
Message 15 of 27
seth.madore
I'm in full agreement there!
Okay, let's circle back and make sure I'm understanding:
You want to select multiple contours and have Bottom Height set to Model Bottom. Okay, which contours are you trying to select? I guess that's where I'm getting lost. If you select Model Bottom, every toolpath is going to be projected there. Multiple contours on the same part, or the part adjacent?
Seth Madore
Message 16 of 27
friesendrywall
It works when I deselect Preview Features:Tool Library
I did not ever check this, some update checked this option for me, apparently.
Message 17 of 27
friesendrywall
Its not complex, here is what I was trying to do.
Message 18 of 27
friesendrywall
I'm still getting an error when I attempt to ramp.
I can't find the enabled feature anywhere yet.  I'm pretty sure its this extra feature erroring out.
Enabled feature flags: setup-sheet-viewer
Generation completed successfully in 186.0ms.
Invalidated: Invalidation due to different value for parameter 'doRamp' with level 5.
Invalidation due to different value for parameter 'rampClearanceHeight' with level 5.
Invalidated: Invalidation due to different value for parameter 'rampAngle' with level 5.
Message 19 of 27
friesendrywall
It would appear this is a bug, as unchecking automatic in process stock generation clears this as well.
Message 20 of 27
seth.madore
Like this?
As you know, Windows 7 isn't supported by Fusion, or Microsoft for that matter. Do you have a Non-Win7 machine you can try this out on? Is an update of OS possible?
Seth Madore
