ManTech CNC
ManTech CNC
Message 1 of 18
ManTech CNC
Anybody know if Fusion 360 CAM is compatible with Man Tech CNC, con see a suitable post on the website
Replies (17)
Message 2 of 18
ChristopherMarion
@Anonymous
I'm sure it can be compatible.  Just because there is no post available on the post site does not mean another cannot be used to drive those machines.
My best suggestion is to upload some sample code and find a post similar and either modify it yourself or find a reseller who can for you at a cost.
Christopher Marion
Technical Specialist - CAM
SolidCAD - Canada
Message 3 of 18
stephen.brindle
Hi I have just got a man tech with auto tool changer  it says on there web site it works with fusion 360 but when I rang them they said you need the post did you manage to get one or is there anyone that has one
Message 4 of 18
seth.madore
Ask them for a programming manual and some sample code. With that information, we should be able to recommend you a post processor that would serve as a good starting point for modification (if needed)
Seth Madore
Message 5 of 18
stephen.brindle
Hi thanks for the quick response I have tried talking to them they are not interested now they have sold the machine . the machine is a Mantech Apollo  manufacturer is man-tech .co.uk if you need to see the machine it does work with vectric Vcarve .what would I have to do ?they did say it might be able to use a franuc post but he was not sure please advise thanks steve
Message 6 of 18
seth.madore
I'd reach out to the manufacturer directly, not the prior owner. Did the machine have any programs stored in the controller?
Seth Madore
Message 7 of 18
stephen.brindle
Hi sorry it is a brand new machine
Message 8 of 18
seth.madore
The manufacturer is not willing to give you some guidance?! That's insane.
Did it come with any manuals?
Seth Madore
Message 9 of 18
stephen.brindle
Yes I no they said they supply Vcarve but we have to get in touch with auto desk to get a post of them the manual is very brief .what would I need to look for ?
the machine all works with Vcarve  it’s just I need fusion to work as it does more 3D and a better program for me
Message 10 of 18
seth.madore
Do you have a demo version of Vcarve and a post processor that works for your machine? Generate some code for your machine and attach it as a .txt or .nc file here, we should be able to get you sorted out
Seth Madore
Message 11 of 18
stephen.brindle
hi have full version of vcare and post for  this machine
tried to send by email but for some reason it wont let me
thanks again for all your help Steve
Message 12 of 18
ChristopherMarion
Hi @stephen.brindle
I just reviewed your sample code.  It looks to be very basic G & M code.  I would probably start with the generic Fanuc post from the Fusion 360 post library
The only code I am not sure of in your file you shared is the M60 for that particular machine.  I've ran machines where an M60 executes a pallet change and some machines where is it for unlocking a 4th axis.  What ever that command is for, a small post modification is most likely required.
Start with the Fanuc post and see how everything reacts.  I'd start with really simple operations and seeing what works and what doesn't before throwing more complex operations in the mix.  You should be real close.
Christopher Marion
SolidCAD - Canada
Message 13 of 18
stephen.brindle
Hi thanks for the help
would this franuc post do the auto tool changer
Message 14 of 18
stephen.brindle
hi had the machine going today the franuc one seems to work but it keeps going up and down the table before cutting and again up and down table after cutting see photos
 and this is the post I used
 is there a way to start the machine above the job and Finnish above the job like I can do in Vcarve thanks again happy new year
Message 15 of 18
stephen.brindle
hi any advice  to my question about why it is going up and down table before it cuts and after it finishes please see photos thanks
Message 16 of 18
seth.madore
This is likely caused by the G28 codes that exist at the beginning and end of the program.
I'd try the RS-274D post processor (or Mach3 post processor) and set it to this:
Seth Madore
Message 17 of 18
stephen.brindle
hi thanks for your answer do you think the Mach 3 one would work as I am use to mach3 soft wear  would this effect the tool changer or is that on the ManTech side (driver soft wear) I don't think this is the right word sorry
Message 18 of 18
seth.madore
The Mach3 post processor does have support for a tool changer, or you can disable that if your machine does not have one. Both of those post processors would give you the option to use Clearance Height
Seth Madore
