Machinist threatening to quit over Fusion 360 CAM bug.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi all,
We design in Fusion and our in house machine shop makes our parts. There is a bug that occurs sometime between the CAD and CAM environments that is so frequent and so frustrating, it is causing major issues with one our machinists, who is so wound up and annoyed about it, that he is threatening to leave us.
This relates to holes and surfaces quite often not being perfectly perpendicular to the face. This is so small, it does not even register when using the inspect tool to measure. If a hole is 0.000001 degree out of square, the drill, bore and threadmill operations will not generate a tool path to cut.
I dunno how this happens, as all features are obviously referenced off existing faces, nothing is intentionally drawn at a very very slight angle.
The solution is to use 'selected point' instead of face, and then use heights to control depth, but this only works for point operations like drilling and tapping.
For thread milling and boring, the solution is to create a sketch on the plane that was used as the z reference during setup, then draw a tube and extrude it through the problematic hole, then select that to drive the toolpath from.
This can also cause problems during cad, for example measuring distance between two planes will often just result in an answer of 0.0deg, rather than a distance, and this can also stop the horizontal tool path from picking the surface up, as its not perfectly parallel.
The problem clearly originates during the design phase, when a hole is made (either extruded from a sketch or using the hole tool) it is being created very slightly at an angle to the surface it is meant to be perpendicular to. This problem then follows the file to the cam environment where it rears its ugly head and causes so many problems.
This is causing problems for him on a daily basis, and it's driving us all mental, and I sympathise entirely with him as it is very frustrating and a long winded solution to resolve.
Could someone from Autodesk please acknowledge this and let me know if this is known about and when we can expect this to be resolved?
