Machining a bowl
Machining a bowl
burquhartGY8VT
Message 1 of 8
Machining a bowl
burquhartGY8VT
I am wondering what toolpath I could use to machine out a simple bowl shape and an angled slot shape.  I have been playing around with a bunch of options but I can't figure it out.  Just for fun I am trying to use an .125" ball nose.angled slot.JPGbowl.JPG
Replies (7)
Message 2 of 8
seth.madore
Scallop, Ramp, Morph or Spiral would all be my first choices for finishing toolpaths. For Roughing, it's hard to beat a 3D Adaptive or Pocket Clearing
Seth Madore
Message 3 of 8
burquhartGY8VT
Seems so simple.  I swear I tried that already but you probably hear that all the time....
Follow up question:  when I do the spiral toolpath everything looks good except the toolpaths continue on well above the necessary point of contact which will add a lot of time to the job.  Do you know how I can get the toolpath to end at the material surface rather than continuing on beyond the z level of the stock?
Thanks again
Message 4 of 8
david.lundbergC7AM5
Check your Heights tab. Looks like Top height is set to "stock top". (?)
/ David
Message 5 of 8
burquhartGY8VT
it was set to .2 and I had played around with different numbers but they didn't seem to have any affect on the toolpath height
Message 6 of 8
programming2C78B
Are you using Multiple Depths?
Please click "Accept Solution" if what I wrote solved your issue!
Message 7 of 8
burquhartGY8VT
yes
Message 8 of 8
programming2C78B
well there you go. It doesn't keep track of your model when you do that, basically just repeats the original pass but with +Z offsets. Use 3D adaptive if you truly want to rough out material beforehand.
