I have made a simulation file with a Haas VF2 with a TRT160 rotary attached. the simulation file functions well, the issue I am having is that my post processor will only post A- directions instead of A+. essentially I want my rotary platter facing the operator side when doing my 5 axis work so I can see the part easier. I can get the simulation file to change A axis directions in the machine builder settings, but I am having a hard time figuring out how to get my NC code to post as an A+ direction. I know this can be done somewhere in the post configuration, can anyone point me to the right area to edit? I am using the latest Haas Next Generation post. I know the axis direction can be changed in the rotary settings file on the Haas control (I used to work as an Applications Engineer) but I would like to avoid doing this and would prefer being able to control the direction in the post itself.
any help would be much appreciated!
