Machine Simulation on machine with dual heads
umairABV9U
umairABV9U
Hey everyone,
I am looking for help with a machine simulation error I am receiving. I have built out a machine sim file for a gantry style machine that has dual heads (z columns). One is a 3 axis head and one is a 5 axis head. Everything works fine in the machine build, all axes move the way I need them to and the kinematics are well limited. However, when I go to select the machine to use in a setup I get an error that says :
I assume this is happening because I used 2 sets of kinematics to build the sim file? See below for kinematics layout:
Not too sure where to go from here, any input or suggestions would be greatly appreciated.
Thanks in advance.
seth.madore
I'm fairly certain we don't yet support dual milling heads in our Simulation, but I will check with the appropriate team and verify.
Seth Madore
seth.madore
Confirmed; not currently possible.
Seth Madore
umairABV9U
Thank you Seth! I appreciate you checking for me.
