Got it, Thank you sir! Machine visibility was on, and I was only hitting simulate. Simulate with machine was the missing link. Much appreciated!
I do have a few more questions. Ive looked in Preferences and sim dialog for these but don't see settings for these.
- Why does the machine model have to download every time you create a new setup? Can't you just select the one from the browser that has already been downloaded into my browser?
- The X axis is locked in my set up when simulating Id like to see the machine movement with the base locked off instead of the table being locked. Not seeing a setting for this?
- When collision detection is on, does this detect every instance of any collision, and does it recognize everything on the machine, including vices, fixtures, tool setter etc if the tool, head or spindle comes in contact with something else it's not supposed to??? How reliable is it?
- When simulating multiple op parts, for example (op 2 of a 2-sided part) is there a setting that will automatically orient the viewport to display the correct orientation of the model & machine or do you have to manually change the view each time?
- Is there a way to show op 1 already machined away like in the real world when your simulating op 2 to help with visualizing fixturing in soft jaws for example?
