Machine Simulation NC Code not working
Koch612
Koch612
Hello.
I have the problem that the machine simulation with a Heidenhain postprocessor does not work when it reads the "Plane Spatial SPA... SPB... SPC..." (Heidenhain specific command for tilted workplane and moving the rotary axis.
Is there a way that the machine simulation is capable of reading that and rotates the axis the right way. For example if the workplane is tilted B-90 but I only have A and C axis the axis must move correctly. With the generic machine simulation post everything works but doesn't simulate the real NC Code
What must be changed?
a.laasW8M6T
Hi
Why not use the Heidenhain post in machine simulation?
You can right click on the machine in the Machine library and select the Heidenhain post From the Fusion Post Library
You will be prompted to copy it to either your local or cloud storage.
Then the machine simulation will use the Heidenhain post to generate the correct moves.
Andrew Laas
Senior Machinist, Scott Automation
Koch612
I have modified the generic heidenhain post but now it doesn't work
a.laasW8M6T
Hi
If you can share an example file with your simulation model selected in a setup and your modified post processor I can take a look
are you able to be more specific about what is not working with the Heidenhain post?
Typically with a Machine definition and machine simulation model, the post will Preposition the Physical axes (A & C in your case) and then activate Plane Spatial to ensure the the Heidenhain control picks the correct solution.
The problem with purely outputting Plane Spatial with no prepositioning is that the Controller may pick a different solution than what machine simulation shows which is why the prepositioning is done.
Andrew Laas
Koch612
I have a NDA on the machine model so I am not allowed to share the machine.
I have modified the post the following way:
Tool Call 1234 Z S4444
CALL LBL 300 (safety position preposition with M91)
Plane Spatial SPA SPB SPC Turn Fmax Table Rot
Then the positioning moves for the job
After the job
CALL LBL 300
Plane Reset Stay
The problem is the machine sim reads everything startet with ;--- until the first positioning moves of the job as a whole block and the axis of the model aren't moved at all. If I use a 5X Job with the L A... C... block the axis move correctly in machine simulation like in real
a.laasW8M6T
Hi
Without knowing exactly how you have modified your post its hard to tell but you are probably missing the
setCurrentABC();
Function in the post that tell machine simulation to move the axes.
Depending on where it is in the post it will take different arguments in the function
see the setworkplane() function in the post processor guide for more information
https://cam.autodesk.com/posts/posts/guides/Post%20Processor%20Training%20Guide.pdf
Andrew Laas
